16v into mk1 problems
(In Topic #117074)
just put a 16v kr with twin 45s in to my 82 gti that not moved in 7 years put a battery on it and thought it would just start !!! cant get a spark and the feul pump not kicking in replaced the relay no better tested fuel pump ok put a short on the ing switch red to black no fuel pump,do i have short on any of the feul injection wiring ie cold start and is the 82 gti wiring the same as the 81 or is nearer to the 83
, whats the colours wiring to a 16v coil ive got a green a black and a brown please help
ps the ingition light stays on dimmer whenthe ing is switch off
nick
nick
coil wiring:
green & red/black = coil - or 1
black = coil + or 15
brown wire is an earth, run that to the cylinder head or battery if it is long enough. are you using the p[roper KR ignition control unit?
Yes using a kr ing unit
thanks
thanks
The cold start circuit is not related to the fuel pump circuit. Are you using the original GTI fuel pump or another aftermarket one? If original, then you'll also need the 5th terminal connected which comes from the coil, its a pulse signal (same as rev counter) and its a safety device which shuts fuel off if the engine stops with the ignition on, eg in an accident.
