1300 driver engine bay wiring help
(In Topic #93405)
![Carbs4ever in the usergroup ‘Old timer’ Carbs4ever in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I have unearthed the two engine bay wiring looms that came out of my driver.
Could someone with a driver list the wires that serve the engine - i.e. temp switches coil etc? a pic would be good too - its the same loom that wiper motor wiring splits off….
Also on the other loom i have identified everything except the reversing light switch wiring?
The only thing left on the loom is a small pin type connector for two wires - should it have a join like this for the reversing switch?
A few pics or descriptions from you 1300 driver owners of engine bay wiring would also be good.
If you can help great!
![yeha in the usergroup ‘Old timer’ yeha in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
another question…
Does a 1.3 driver have an oil buzzer?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Golf%20Ava5.jpg)
![markwon in the usergroup ‘Local hero’ markwon in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
1983 1100 C
1983 1100 C
