12v feed needed from fusebox where ?? (g60 wiring loom)
(In Topic #163490)
hi there im looking for a 12v feed from the fusebox of a 1991 late clipper cabrio
it needs to have 12v while cranking so as not to interupt the ecu for the g60
i think ive got most of the other wires done to where they should be but seen a few comments when looking around about the live feed for the ecu
and getting a power spike and damaging the ecu any help greatly appreciated
thanks matt
thanks matt
jammie dodgers rule
the proper way to do it would be add an ecu relay, either by cutting plug R out of a CE1 digifant engien loom or adding a relay holder above the fusebox. i would use a VW relay holder so it clips on nicely, then wire it up:
30 - live
85/31 - earth
86 - ignition live from d2 or d7
87 - output to ecu
the later G60 use a #30 ecu relay, if so then get one from VW then wire it as above and in addition pin 86a goes to the G60 ecu pin 23
30 - live
85/31 - earth
87 - output to ecu
thanks rubjonny i was hoping you would comment on this one i have a relay in front of me with 87 86 85 30 terminals so if i connect that up that should do it but do i have to do anything with the blue yellow wire from the ecu ????
jammie dodgers rule
the ecu blue/yellow is probably the fuel pump relay trigger wire to g1/3, if so this goes to D/13 on the CE1 fusebox and you fit a 67/80/167 relay to slot 2. power the pump, lambda heater and injectors from E/14. run 2 wires to this pin, 1 to the pump and the other to a male spade, then pop the injector/lambda wire into a female spade and plug it in. just like factory
