1.8 GTI wont drive at night ?
(In Topic #89981)
well … few days back my car died at a petrol station since then i've hooked up a multimeter from the battery into where i sit
so i can see whats going on with the charge etc … well .. at night with the lights on etc … the battery drops .1 every 7 seconds
battery starts off at 12.87
i was out for … about a hour tonight … and i had to bomb it home because it started dropped really fast
O btw … in the day … it holds it charge but it stays in the 12.40-12.90 range
is the my alternator ? :dontknow:
What's the voltages of the battery just before starting, just after (with the alternator light still on), and then just after you've revved it up and the alternator light goes off; and then say 5-10 mins after the car's been running?
but before turning the key its 12.89
then when the ignitions on buzzing its 12.59
then when the engines running it stays up in the .70 range
doesnt really decrease in the day time ?
chris_VW_1987 said
The battery light on the dash … actually .. doesnt work …
It should do. I'd put a voltmeter on the blue wire off the alternator, to see if it works directly.
chris_VW_1987 said
theres nothing on that blue wire ? no volts
WHen is there 0V? Try it with ignition on but not started; just started, not revved up; and started and revved up to, say, 2000rpm.
wtf ?
chris_VW_1987 said
hmm i got a flash of voltage but its not constant ?
WTH ?
This is no use - you're not providing enough information. Whats "a flash of voltage" and when do you get it?
Mike.
1983 White cabriolet GTi
because I've gotta get to Essex , who's rewiring my car electrics entirely
like , i noticed
for the first 40 mins the battery starts above 10v but after the 40 mins
it drops rather quickly … also
the battery today was showing 12.51v …. then i tried to start the engine and it dropped to 6v , the engine didn't start it sort of went " Clump" lol … so i tried to start it again and it worked and the voltage shot up to 10v but kept falling quickly
should i swap the alternator for another spare i have ? just to get to essex or should i just charge up loads of battery's ?
New bonnet on the way. :-)
stop p*ssing about
the alt has a set of diodes in it that control the amount of charge it makes. under more load( lights, radio, heater, etc) it will use more diodes to allow more current to be made. if the diode on the high side is burnt out then it sill make power just not enough to compensate for the higher load needed at night.
i worked for an auto electrican rebuilding starters and altenators.
pretty boring didnt last long.
go to halfords they can do a free test on the charging system.
if first you dont succeed. read the instructions.
