(TITLE CHANGED)how do i get to the ignition switch?
(In Topic #110295)
i assume there will be a relay somewhere??? (where?)
mine starts fine most days but sometimes is totally dead :x ! i get ard this by shorting out batt plus to top connection on solonode then it turns over n fires, (i have to time it right with the clifford alarm or it just turns n turns n turns lol)
or does any know were i can find a elec schematic for a H plate Rivage????
thx
Sounds like a dodgy ignition switch - a common issue.
i undid the allen bolt that secures it ard the coloum but cant get it of!!
HELP PLZ
still cant work out how to get to the contacts in the ignition switch,
and now i'm sporting a hole in my left hand the same size as my screwdriver end
gone abt 30 pages back here but cant find the info needed HELP PLZ
1) Remove steering wheel/stalk cover (The 2 plastic pieces) with 2 screws/nuts
2) Undo steering wheel and steering wheel nut
3) Remove 3 screws that secure stalks + Stalks
4) Remove Black rubber/plastice steering 'boss', use large flat bladed or butter knife, (anything large flat and metal to prise it off)
5) Undo/Loosen Allen key to ignition and pull off steering column
also amongst that is disconnecting the plugs and wires to the stalks/igniton column.
I think thats all there is to it, not sure if you can seperate the ignition switch from the column part itself, but I do have a spare switch section, so it must be possible in some way, although maybe not without destroying the steering lock section.
Should only take about 30mins.
~Madferret
Mk1 1457cc 5door GX '83
ive undone the allen key but didnt want to yank at the peice as i noticed it has a bearing facing u, do i just need to be brave and give it a pull towards me? thx
