VDO Gauges
(In Topic #97178)
OK, i'm stupid.
Just looked on GSF & eBay,
GSF list these:
93447 OIL PRES SWITCH VW/AUDI PETROL ENGS 98> 1 PIN BLACK(1.2>1.6 BAR) 4.50
93448 OIL PRES SWITCH VW/AUDI PETROL ENGS 98> 1 PIN GREEN(0.30>0.60 BAR) 5.60
93449 OIL PRES SWITCH VW/AUDI DIESEL ENGS 98> 1 PIN BROWN(0.55>0.85 BAR) 5.60
93450 OIL PRES SWITCH VW/AUDI DIESEL ENGS 98> 1 PIN GREY(0.75>1.05 BAR) 5.00
93440 OIL PRESSURE SWITCH G1 >7/78 2.50
93441 OIL PRESSURE SWITCH G1 All 2.70
93441A OIL PRESSURE SWITCH(BLUE) G1 All 2.50
93443 OIL PRESSURE SWITCH G1 All 2.70
Am I barking up the wrong tree? :dontknow:
GSF list these:
So the dials have arrived, here they are.
I have also been to my local audi dealer and looked up the oil pressure sender out of an Audi 80.
They said that there were 2. Which one do I need?
035 919 561 Oil pressure gauge sender 0-5/0,3BAR ?56 + VAT
035 919 561 A Oil pressure gauge sender 0-5/1,8BAR ?61 + VAT
I'm toying with the idea of fitting some ancillary guages to my Scirocco, and stumbled across this outfit:
http://www.etbinstruments.com/index.htm
They do their own range of instruments and senders as well as VDO. Their prices seem reasonable too, if you do give them a call I'd be interested to hear what you thought of their service.
Chris
Chris
Chris
1990 Scirocco GTII
2001 Jag S Type 4.0V8
1990 Scirocco GTII
For what its worth.. I finished up getting an oil pressure sender from the USA. You need 0-5 bar (80 PSI). It screws in the end of the block. Dealer is Don,s motor sport. at www.eGauges.com. Part 360-006 M10x1K thread with a 7PSI low oil pressure switch. This sends a variable signal to the gauge and has a contact for the low oil pressure light. Cost 28 USDollars for sender & 20 USD for shipping. hope this helps.
Beetle restoration. Cabrio GTi (black and shiny). Golf driver.
16v MK2. (Oak green) Now on a Clipper (to keep). Audi A8 4.2 Quattro sport and a BMW R65 bike.
VW part No for oil pressure sender...035 919 561 0-5 bar. M10 thread. 2 pin.
Not as far as I know. We get the part number from a VW system called EKTA which is on CD. The dealers though have an online version where they get their prices. Just give a VW dealer a ring with the part number to find out. VW and Audi will be the same but as this is Britian I think you will find that the US price will be cheaper. Keep smiling. J.
1988 1.8 carb Golf Clipper
Thanks DJ..you learn something every day.
After fitting my oil pressure guage and sender, both bought second hand, the gauge goes all the way to the right when the ignition is turned on. Even when the engine runs the needle doesn't move anywhere. The sender has been fittied on the top of the filter housing and both gauge and sender are 0-5 bar items.
Hoping that someone can shed some light on the problem.
gauges
Hi I had the same trouble when I wirin in my gauges as per the vdo site, I swopped the earth and the sender wires around and now their perfect. If they are older ones the wiring positions are different look for the symbols on the back of the gauges.
Alex
Alex
I'll give it ago and see if it sorts thing out.
