ignition switch change
(In Topic #75922)
has anybody changed / or knows how to change the ignition switch. Does it involve drilling and removing the lock… or do can you just remove the switch section only….
any hints and tips..
stu
I'm sure someone else had the same problem on here and got VW to do the job in the end. I can't find the post though.
let us know how you get on, why do you need to remove it?
Cheers,
Ross
It all depends on which part of the thing you want to replace whether you need to drill or not.
But from what I seem to remember reading, the later cab has a slightly different setup but I can't confirm this. Theres nothing about a change in the haynes either.
On the older models the switch is held in place with a screw… but on the later models there isnt one… wether its a push fit or something i dont know…
Cant be a common problem…
cheers stu
stu
Buy a new one and you may be able to work out how it fits? :dontknow:
stu
stu
1. remove the steering wheel
2. remove the cowling around the switch/starter
3. remove the 4 slot head screws which hold on the ignition/light stalks etc, and pull back the stalks
4. remove the 8mm allen stud wihich prevents the barrel from spinning on the shaft.
5. At this point the barrel can not be pulled back due to a splined collar, hence you need small double, or triple leg bearing pullers to remove the collar.
6 remove the spring that is also on the shaft onc the collar has been removed, the barrel can then be reomoved from the shaft.
7. the ignition switch is held on with one screw at the back.
as haynes say ..removel is the same as refitting
be careful when refitting the collar as you are pushing against the resistance of the spring so it is quite difficult. i managed to push it into position then tap it home with a small socket and nylon hammer.
The splined collar? Is that the adaptor for fitting the later type steering wheel to the Mk1 or is it another collar all together?
Cheers,
Ross
