Fuel Pump Relay Control
(In Topic #73753)
Very occasionally the fuel pump just will not run. When I have this problem I have inserted a manual switch on the fuel pump relay fuse box contacts and operate the pump manually. Car runs fine.
By the time I get round to looking at it - I'll bung the relay back in and it'll work fine.
This time I've managed to look at it when I have the fault!
Things i know:
Not a pump pr pump wiring problem
So must be a relay or relay control problem.
I have tried another relay in the past but it did not solve the problem, so I went down a relay control problem route…..
On the Fuse box there are three connections:
15 - Connected to one side of the coil
31 - Switched 12v from ignition switch
31b - Connected to the other side of the coil
I've measured voltage in three states:
Ignition off:
15 - 0v
31 - 0v
31b - 0v
Ignition on:
15 - 12v
31 - 0v
31b - 12v
Engine cranking:
15 - 6 to 12v
31 - 0v
31b - 12v
This all seems fine. Double checked voltages on the Silver Campaign and all were the same so I did a bit of head scratching. I know the Silver Campaign starts on the button - tried starting it today after 2 or 3 weeks and it fired on the first flick and settled to a nice tick over within a second or so. The relay must be good. Tried it in the black one and hey presto fires up straight away.
I think the thing that gave it away is that with the Silver Campaign and the cab you can hear the fuel pump buzz for about 2 secs before cranking the engine. I don't think the black one has ever done that!
So problem sorted after months, ney years of messing about all cos i tried aonther relay and that must've been bad also
when I try starting mine the fuel pump doesn't start for a good few seconds of turning over (think the inlet manifold gasket is part of the non-idle problem i've got so got a new one to put on)
think I should replace the relay as well?
also on the subject, does the fuel pump stop pumping once it's up to pressure? or am I talking nonsense?
My Build Thread
