buzzer?
(In Topic #73016)
buzzer?
it goes off after a while any ideas?
1)the dash
2)bad earth to the dash
3)the sender
4)the wire brekaign down (blacking maybe)
Before doing that though, check the wiring to the two oil pressure senders on the engine - one is on top of the oil filter holder (blue/black wire) and the other is on the end of the head, at the gearbox side. The engine end of these wires get brittle from the heat of the engine, and a wire breaking up here is common.
Assuming that all the above are ok, then the issue is usually the circuit in the dash unit - see more details here:
http://portal.campaignregister.co.uk/modules.php?name=Forums&file=viewtopic&t=823
have been having the same trouble as the fella above. have tried all the above except for the dash wiring. tried to connect to your recommended link and it wouldn't work. do you maybe have the info?
thanks
nick
Try this version of the link and you should be ok:
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=823
This means that taking the wire off the sender stops ANY voltage going to earth, and the gauges are designed to show bad readings in this case, as a safety measure.
also had the dash out and then realised i had no idea what i was looking at. someone has grafted in positve and negative leads to one of the switches that clipped onto the bottom right hand side of the dash, (fits over a circuit membrane)…i can't work out what this might be for…circuit diagrams just send me crossed eyed! any ideas??
sorry for all the questions, would much rather do stuff myself than send it to a mechanic…much more satisfying if i get it fixed…if!!
Make sure you have the correct wires going to the correct switch. When I get home tonight I?ll have a look.
My flashing LED goes off occasionally an a rapp on the instrument cluster with knuckles usually clears it. :roll:
To make sure you don?t really have a problem use a VDO pressure gauge and sender. There are always some on ebay @?5-?20. You are best with the ones that go from 0-10bar rather than the 0-5bar out of an Audi types. :wink:
i haven't tried checking the wiring yet as i didn't want to go on without sorting this high pressure problem…is it a problem, am i doing something wrong here??
maybe i'll try looking at the electrics side and see if that helps, just won't take it for any long journeys for now….just to be absolutely sure!
thanks for your help by the way….
…and I lay bets that there is nothing wrong with the oil sensor r buzer wiring too.
See, the oil pressure you have IS was too high and what I suspect is happening is that the oil is presurising in the sump. The reason for this? The achilies heal of all VW engines, the oil breathers.
I suspect your oil breather is full of carbon and the engine's oil system is now effectiely operating as a sealed unit. This is very common on VW engines, I've had to do the oil breathers on pretty much every VW I've had, as did my father before me on all of his.
Now it depends on the engine you have fitted as to where your breather filter(s) will be located. On the small block motors (1100 and 1300) they are on the back of the block under the inlet manifold and above the starter motor. On the Mk1 Golf they are an "interference" push fit which means you will severel skin your knuckles tryng to change it. On the later hydraulic engines they are held in with two allen head bolts.
Not sure about the Mk1 GTI but on the Mk3 GTI 2.0 8v the breather is located on the front of the engine block. There is usually a second gause breather inside the rocker cover.
I've seen the so gunked up that you can't even blow any ir through them. If you can't find the breather filters check in your manual or look on your inlet side, usually near the throttle body/carb on in the air box.
There will be a rubber pipe, about 1inch diameter, the disappears off somewhere. It will usually just be pushed on but it may be held on with a clip. Follow this pipe to where it ends and you will, 99% of the time, be looking at the engines oil breather pod.
Change/clean this, check the oil level and forget about it - simple as that.
Most "my VW has an oil problem" issues are related to blocked breathers.
Kind Regards,
Steve Matthews
1983 Driver on roaring forties…
PS. With the oil sender wiring disconnected the buzzer will not sound until the engine reaches 2000 rpm after startup, after which point it will wail its teeth ginding tune until you can bear it no more and kill the ignition.
i'll hopefully get a chance to look at the breather pipe etc this w/end and then i'll post the results in case anyone else has a similar problem..
thanks again for the advice
nick
cant be oil filter etc as just had full service. am blowing a little blue smoke tho !
Ed
