td/na differences?
(In Topic #156645)
I know it sounds a lot of work and wouldn't entertain the idea if it wasn't so low mileage with history and so cheap. but I had planned on changing the pump and turbo eventually anyway
Bert said
the aaz has oil squirters to cool the pistons,the head is a better alloy what i was told once? and the pump injectors,manifolds clutch and the block has a oil return for the turbo
Bert
Thanks for the reply! I hadn't considered oil returns etc. I suspect an different crank too. on reflection id be better off putting my efforts into refurbing a high miler aaz.
I did think of a 1y but I'm pretty obsessive with it looking factory fitted so the aaz does look to be the way forward
~ Craig
'77 Golf 1.5D
I love it. if mine ends up half that good i'll be a happy man!
markar said
you see bert thats what in talking about, it looks at home there, like a guy called claus put it in on a production line in wolfsberg in 1983!
it wasnt claus it was heinrich 8-)
or do a PD if you want to bypass the TDI era like the one im currently doing
Bert
I seem to remember reading on the caddy forum its just a plug into the fuse box jobbie. is there any truth in this? and would the caddy loom be different the later the model?
