AHU conversion
(In Topic #208527)
Howdy folks, just stripped a vw sharan I had of its engine and box Just wondered if its complicated fitting it to a 1981 golf cabby ? Mechanically I'm not worried just the loom end of things. I dont know anything about diesels and I see people swap these over to mechanical TDI .Any info appreciated. Many thanks.
Last edit: by gafo
Last edit: by gafo
Back again folks , Does anybody have a wiring diagram for the 1997 Ahu they could post? Thanks
Last edit: by gafo
Long shot but you might try
rubjonny
Thought I posted this earlier anyhoo. I've labelled all connections to engine, I'm trying to sort out which wiring I don't need like headlight , wipers, etc .Do I start stripping the tape from the loom and try see what's going to ecu and bin everything else ? I presume I need some connections left in that go to the fuse box ? Which ones ?
Last edit: by gafo
Sorry for spelling errors, feckin phone
Been at this again , I'm not sure about these connectors whether I need them or not ?
Been sifting thru old threads, project builds etc and I'm none the wiser regarding what I need off this loom, all the transplants seem to be installed without any posts regarding what wire goes where, Been looking at mtdi also, am I tight I'm thinking that I can use an aaz pump gtd boost pin and go away with ecu altogether
sorry just seen this post..maybe this could help ?
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&type=misc&id=your-mk1-golfs_2%2Fgolf-1-6-diesel-now-1
