1.6d hard to start
(In Topic #215083)
1.6d hard to start
1983 VW golf mk1 1.6 dsl.
1987 VW caddy mk1 1.6 dsl.
1986 VW caddy mk1 1.6 dsl.
1989 Jaguar sovereign 3.6 auto
1978 Mini clubman 998cc
1972 Mini 850cc
1989 volvo 340gl 1.7- sold
1989 Mitsubishi shogun 2.5 tdi
1972 Mini 850cc
But what do you see coming out of the exhaust once it's running? 🤔
A cloud of white smoke.
What do you see on the under side of the rocker cover oil cap after the engine has been running for a while? 🤔
Something resembling white cream of just normal engine oil.
You seem to have a long list of various cars and you may have already looked at these things but it helps the members looking at your post if we clarify some things! 😉 👍🏼
The oil in the rocker cover is just oil no water.
1972 Mini 850cc
1972 Mini 850cc
I would suspect that you have 2 cylinders that are needing attention.
300psi is so-so, I thought it was to be @ 350-400
2 weak cylinders are bad, so they all need to be addressed
I have had folks with similar issues that had honed the Cylinders then replaced the rings to good success.
Was that a wet test or dry…
Second I would test your glow plugs as if you have bad ones on the good cylinders that is probably why it wouldn't start.
White smoke on start is usually condensation burning off the exhaust internally. Gray is is oil/water burning, and if it stops then that is a sign that your rings and pistons have expanded due to engine getting to temp.
White sweet smelling exhaust is A/F burning. But you will also notice that your radiator hoses Swell…..
One quick test,
Tie a latex glove to the expansion jugs openening (take off the cap) Tie it tight.
Start the car, and from under the hood rev the engine to 3000 rpm for 30-45 seconds, if the glove inflates and gives you the finger, bad head gasket
Now with that said you may have cracks between the intake and exhaust valves, small cracks are normal large ones aren't.
The compression test was done dry.
All glow plugs are relatively new and I can see them all glowing because the injectors are now removed.
I done a leak down test and there doesn't seem to be any leak into the coolant tank or through the intake/exhaust valves.
I will have to take the head off and see if the cylinders are worn. Am I right in saying that I won't see a wear lip since the pistons come up past the top of the head?
It would be good to get away with changing the rings rather than having to get it rebored.
1972 Mini 850cc
1972 Mini 850cc
I would at least mic the cylinders to determine how bad they are off.,, but it could be a broken or worn ring that is all the issue is…..
Also the piston ring grooves wear and the new rings can move up and down in the groove. This causes the oil to hydraulic up past the ring and add to the oil consumption. You need a bore guage to accurately measure the bores but you can usually get an idea by the lip where the rings come to the top of the bore. There will be a deeper lip on one side of the bore compared to the other.
1972 Mini 850cc
1972 Mini 850cc
1972 Mini 850cc
1972 Mini 850cc
