Waistline trim clips
Need new clips to put on the waistline trims I bought (Black plastic style on a clipper) and I see that there are 2 sizes of clip, do you have to get a specific size or will either do? And also is there a good knack to fitting and removing these clips without breaking them? Thanks
thers a little circular thing in the middle you need to push out then just pull them off.
you can get bags of new clips from ebay which include grill clips, waistline clips and another clip :)
South West Regional Host
Previous;
Current;
http://bit.ly/1ml7CtI
Lots more like this on eBay
Just push the centre circular piece through into the inner door and then the clip will come out.
Then do the opposite when you put the new clip in, just put the clip in and push or tap the circular piece back in.
Ahh right so they're just like a small rivet, cheers, do you know about the different sizes? Or assume any will do
I found the cheap ebay ones where too small ti grip the side mold.. bit the bullet and bought the heritage ones.. gulp they are not cheap !
Work on my Clipper
Clips on ebay dont fit, got mine from Mark at Vw classics, pence each and fit spot on
Instagram Firemandan1
It's the white smaller ones you want and better if you get the ones with a little gasket, the red ones are usually for the chrome trim running along the sill (not fitted to cabriolets), black ones for the grill.
If you can get behind them you can catch the pin which drops out and reuse them but it's not always possible to do this.
Info on different clips in the ad
http://www.ebay.co.uk/itm/VW-GOLF-MK1-GTI-TRIM-CLIP-SET-C16-/200527157026?pt=LH_DefaultDomain_3&hash=item2eb0599722
