Removing polish from rubbers?
(In Topic #145061)
I've heard wd40 is good.. anything else?
The oils in it do the trick.
CarPlan Black Trim Wax 375ml | Car Plastic Restorer | Halfords UK
Dan
expensive for small tub but good stuff
1.8T CABBY
1.8T CABBY
It doesnt work everytime, depends how bad it is.
Few times ive used it, its been ok.
Linseed oil is also good so I here but I've never used it myself,
Warm it or bring it to the boil and put on seals, but as said never tried it
Saab 93 diesel daily
Will try glass cleaner if that doesnt do the trick pop to halfords and buy something.
I would take the trims off and give em a scrub etc.
jarynn said
Ive already got that black to black car plan tub and its rubbish.
I found it quite good, depends I suppose how bad yours are thou.
I take it your after something to remove polish residue which is completly different???
Over time treatment of trim remove residue anyway…eventually
i alway use autoglym fast glass with a microfibre cloth
hope that helps
What I do is use some fresh polish and take it off straight away. It works for me! The polish I use is Autoglym super resin, my rubbers are quite good so not sure if you'd get the same result with slightly perished rubber. Rub it in hard and take it off hard and straight away! will also make your rubber look nice! as for polish on plastics I use trim restorer.
