Pirelli P Slot Centre Caps
(In Topic #184773)
Hope someone can help with this ?
Numbers On Back Side: 191.601.149A
24045907
Physical Size: Approx. 6 1/2 Inches Wide
Center Cap #VWC12 (Silver W/ Black Rim)
Numbers On Back Side: 323 601 149
191 601 149 G
1-4180-1 WZ 1
Physical Size: Approx. 7 Inches Wide
Center Cap #VWC40 (All Silver)
Physical Size: Approx. 6 3/8 Inches Wide
Nothings ever simple as it seems !!!
Hairyarse said
Yes they'll fit no problem
cheers hairyarse I just found this ! the ones I have are the 191.601.149A
http://www.hubcaps.org/options/vwc39options.html
partsbase.org
Hope that helps too
and vice versa, the mk2 blank cap is extremely tight in a mk1 wheel, so much so that getting it in, or back off again is very difficult.
Im away at work at the moment so cant take any measurements or part numbers im afraid
Do it once and do it right! ok, we've identified the problem, lets not make it worse by guessing……… Identifying the sympton is not the same as understanding the cause
