How I refurbished my badges!
(In Topic #188347)
A guide to make your badges look spanking!
The reason I have decided to refurbish them is because I can't find a new Golf CL badge, I know I can get new a Volkswagen badge but I thought I would trial run the process on a badge that I can replace if it goes wrong, so I started with the Volkswagen one..
My badges had already been painted with silver nail varnish (don't ask)
I used 1200 grit wet and dry to rub the entire badge, I then used a degreaser (Jizer) to clean up the badge and remove any polish/wax residue. Cotton buds came in handy for this bit.
Using a tack cloth I wiped the entire badge to ensure that there was no dust or dirt on there.
I then gave the badge 5 very thin coats of satin black spray paint so that it looked like this
Once dry I could start the tricky bit, I placed a small piece of sticky backed foil over the first letter and gently, with a cloth, rubbed the foil down so that I could see the letter underneath.
Using a craft knife (I suggest a good quality knife for this bit) I carefully cut around the letter until I could remove the excess foil.
I continued with this method until I had finished all of my badge
I am extremely happy with my results and I will be starting my Golf CL badge tomorrow, once complete I will post a picture up of that badge too.
It has taken a lot of patience which I do not normally have and it was a struggle at times but I managed to get a good technique and after spending 45 minutes doing the first 5 letters it only took me 15 minutes to do the last 5
Overall it has cost me less than £10.00 and I could probably do another 50 badges before I run out of paint or tape
Goly The Golf, a 1983 5dr 1.3cl having a full resto.
I'll send mine over then ; ) Great job!
MK1 Campaign Helios Blue, MK2 Rallye Blue Pearl, MK1 Clipper Cabriolet Black & Corrado VR6 Storm Mystic Blue
skipper1 said
Thats excellent mate,great idea & alot of work you put into it
Thanks skipper1
shepp said
where did you get the silver foil from?
Hi Shepp,
It is available from Toolstation http://www.toolstation.com/shop/Adhesives+Sealants/Tapes/Aluminium+Foil+Tape+50mm+x+45m/d180/sd2420/p97723 , I'm not sure if you can get it from places like B&Q but I guess they will be more expensive anyway.
I've started sanding the Golf CL badge and is it sad that I am excited about how it is going to turn out?
Would you guys put some clear coat over the finished item to make them last longer?
das_auto said
Top workim going to have to give this a go
allenrobin2002 said
This looks fantastic. I was trying to work out how to do something like this and now you have given me the solution. Thank you
I managed to get the CL badge done yesterday! I think I could have made it a little better but I'm just being picky! I'm going to put clear coat over the Volkswagen badge later to see how it looks.
Website Manager
I did not clear coat the first attempt and after a while in the elements the aluminium foil showed signs of oxidation.
So I did them all again and clear coated the second time.
Then some brand new genuine badges became available and I just couldn't resist !!
This is exactly what I will do
Shughy said
Nice job - looks spot on.![]()
Well done. I also ended up buying new ones.
Thanks Hugh,
Keep your eyes peeled for a new Golf CL badge for me if you can! I've not managed to find one yet but I'm sure one is out there!
1985 GL Cabriolet - Long Gone
Several GTI Tintops - Long Gone
Mitsubishi L200 Barbarian 2013 - Daily Workhorse
ridders said
What a great idea and really glad you took the time to share you work. I too will be giving this a go and would prefer to refurb mine rather than buy new just for the satisfaction. I would finish with clear coat to protect the foil.
I didn't paint the plastic as without etch primer and the right paint it tends to flake off over time, a light sand (800 grit) and a clean with a tack cloth was enough to let the tape stick fast, didn't clear coat and wont be doing it this time either, the tape is designed for use on HVAC ducting, a days curing and it's stuck for a long time.
