Hammerite Smooth or Hammered
(In Topic #151382)
Which paint to use?> on gearbox engine etc
just wanted to know which Hammerite paint is best, hammered or smooth and will it be ok to use on the block>?
as i have heard people use hammerite with 2 coats and they have said its fine?
any thoughts?
thansk
Birmingham
Both are rubbish!
I have just painted my callipers and carriers the same was and covered it a treat.
Everyone is different and unless your stripping and either anodising or powder coating this is a good way as long as you prep correctly
Can't beat a German car
Just one more thing, with hammerite, if you paint 1 coat is it easy to smooth out with wet and dry after its hardened and dried?
thanks
Birmingham
c11rgd said
will check those out, thanks.
thanks
Why would you want to do that to a top coat of hammershite?
Its a bodge paint to cover rusty iron railings!
Birmingham
I used Watco Rust Stop paint on lots of parts and its worked very well. They also do a great product called Primebase which is a strong rust convertor to put on first.
http://www.watco.co.uk/watco-rust-stop-metal-paint.html
S
