Hammerite smooth
(In Topic #174050)
Dan
If you're getting runs it sounds like it is being applied too heavy.
might be best to wait until spring! Thanks for all the input though.
Anything in the engine or suspension I've painted with it seems to develop rust after a couple of years.
I've now taken the hammerite off and used an epoxy mastic, great stuff with some great reviews, been on my car for 5 years and still looking good.
http://www.rust.co.uk/products/category/28117/epoxy-mastic-rust-proofing-chassis-paint/
Stu10002000 said
I've had the parts indoors for a couple of days so they were at room temperature, the Hammerite is also stored indoors. Was spraying each coat outside then bringing it back indoors between coats. Possibly the cold air outside causing the issue?
I think the change in temp could the contributing factor then. The weather at the moment especically where I am is very damp also so with that an the change in temp is not a good combination for applying paint.
Last time I did a few parts I did it in my kitchen much to my wifes discussed!!!!
