Engine Block Paint
(In Topic #152662)
I'm having to brush mine as I'm not taking the engine out and I got high temperature black paint from eBay.
I can't remember the make off hand and its tooo dark, late and cold to go looking for it in my garage.
If no one else posts up I will get I the make and I should hopefully be doing mine in the next few weeks, so I will get back to u on its performance.
Chris
Mars red Tin top 83' gti in progress
VHT Engine Enamel™ -- High Heat Coating
http://www.frost.co.uk/por15-engine-enamel-paint-473ml.html
Here's mine in plastikote for reference
and it still looks good almost 6 months down the line (exscuse the messy bay
Shughy said
Did mk1 golfs come with a green or black engine block?
Black
My process for the engine block clean was degrease block using a paint brush to agitate the grime, wire brush the hell out of the block, then degrease again. A splash of white spirit as a final clean applied with a paint brush. Then I genolited the block (rust convertor) then several coats of Plastikote. I then had the whole block dipped which cost a tenner @ a local engineering company. It dulled the paint (which I expected but atleast I had protected the block and finished with wire wooling and creating loads of dust etc). I then masked the block up really well & added a few final top coats. Job done!
& here it is after the wire brush treatment:
& this where I am at just waiting to build it all up - was waiting on my sump coming back from the powdercoaters and the weather improving so I can shift it into the garage!
Hope this helps
Hairyarse said
Black
Hi,
I've got green blocks on my diesels…
Robin
VW Golf 1500D 5-door 1978 - was daily (wet)
VW Golf 1800 cabriolet 1980 - daily (dry)
Bedford CF Trailblazer 1978 - camper
Bedford CF 350 Flatbed 1976 - fun/work
Mercedes W108 280s 1970 - dusty and forgotten
Mercedes S123 200T 1983 - to be renovated
Mercedes C124 1989 - Winter Beater
BMW E21 1976/82 - dusty but not forgotten
Twingo 2004 (not my fault, somebody gave it to me!)
