Engine Bay cleaning
(In Topic #191187)
88 Clipper- Never seen a steam clean!
As you can see the engine bay does not currently look the prettiest! I was just wandering if anyone might have any suggestions for making it looks a bit prettier? Currently I have the fan cover, bonnet prop, washer fluid tanks and coolant tank out to be either cleaned or powdercoated. I am also intending to steam clean then engine bay (After to carefully placed cling film has been placed on the electrical bits and the battery is disconnected !Any other recomendations for making it look nicer without pulling the engine out ?
Thanks for any and all advice,
Ben
You could remove and paint the brake servo plus a new radiator top card from
Then it's a case of how far you want to go, painting every little detail or replacing bolts and fasteners etc with new?
If using the car every day don't steam clean the engine bay it as VW put the wax there to stop it rusting, it looks like it's done a good job for the last 26 years so why remove it now.
Steam cleaning the engine is OK and may be paint the rocker cover and some other bits which look a little rust will tidy it up no end.
P.S Change your expantion tank cap for a blue one while your at it as the black ones can course problems with over heating.
Do you have any advice for my rusty bottom end ? (oooerrrmissus) Is there a way to treat prep and brush paint it with out taking the block out ?
Thanks for the advice already guys!
I have used Autoglym engine cleaner on mine and works a treat spray it on and dab a brush at it - little bit at a time.
Gunk and bug and tar remover with 45 degree angled paintbrushes.
Autoglym rubber and vinyl cleaner and Autoglym bumper gel.
After
Even did the brake master cylinder reservoir.
The wife gets a surprise every time she opens the dishwasher. (Is that another oooerrrmissus)
So now I get up at 5:00am, which gives me at least two hours to get the job done and get the hell out of the kitchen before the Dragon 🐉 surfaces from her den!
Its stare can kill a Man at 50 paces, no problem .
golfcabrio said
Nearly got my dingle dangle removed the last time I used our dish washer!![]()
So now I get up at 5:00am, which gives me at least two hours to get the job done and get the hell out of the kitchen before the Dragon 🐉 surfaces from her den!![]()
Its stare can kill a Man at 50 paces, no problem .![]()
I didn't realise we married the same woman
I didn't realise we married the same woman![]()
Chris I'm guessing you are Married to a Scottish Lady.
To be honest I don't know what's worse.
A. A Woman scorned
B. A Woman Scottish
Or
C. A Woman Austrian
And mine came down from a mountain 🗻 region where the Men are Men and the Sheep 🐑 have a very worried look on their faces !
