Bonnet catch bolts/vin plate
(In Topic #201605)
Last edit: by MK1CabbyWhite
I'd like to keep the original on the car for authenticity but that sounds like a good ornament for the wall!Golf Cabrio said
I would leave the VIN plate alone and mask it off.
The bolts will work but you will need to get access to the bottom of the catch so you can hold the nut while doing up the bolts so you may need to remove the grill?
I was thinking mainly out of cost as I don't have a rivet gun and will have to buy one but that's not a big deal, do you know where I can find the correct rivets and if they're the same size for all the plates on that panel? And the grill is already off at the moment anyway so that's not an issue I have enough tools to get access up there if needs bemark1gls said
If you really want to remove the plate why not pop rivet it back on once finished? The bolts will not look same.
Regards Volkswarren
If I can find them readily available that's what I'd like to do, can't seem to find them online anywhere thoughvolkswarren said
id dril them an buy new rivets from vw
Regards Volkswarren
Yeah will have to just thought it would be something more readily available at heritage etcvolkswarren said
You need to speak to a dealer.
