Bulk of parts from garage clear out
(In Topic #221359)
Can try and sort postage for some items if preferred, located in Honiton, Devon.
- 02A CTM Gearbox (Close ratio 1st, 2nd 3rd) - £150
- Raceland front upper strut brace - £30
- Front lowering springs - £20
- New Falken 175/50/R15 tyre - £40
- Brand new unused Classic VW Stainless Steel brake lines- £40
- Fuel tank with internal lift pump. Pump is in good condition, the tank needs work externally - £50
- 8v GTI rocker cover - £15
- 8v carb rocker cover - £15
- 020 gearbox 3.6 Final drive - £30
- Earlier scirocco front hubs and 256mm discs (no calipers) - £80
- Werk 34 Metal bumper bracket (New) - £15
- Black side trims, some are bent but some might look OK when fitted, 1 of the lower trims is brand new from VW heritage - £20
- Chrome powder coated bonnet stay, a few wobbles but brand new - £15
- New Topran mechanical fuel pump - £10
- 4x Standard BBS RM lips, need a refurb - £40
- BAM ko4 injectors and fuel rail, came off a running car but I've never tested them - £20
- Original passenger side tail light (Frankani). Small crack in lense but could be a good spare - £10
- 1.8 Cast Iron exhaust manifold - £20
- Mk1 Caddy Rear bumpers - £30
- Pair of Headlights - £25
- Single LHD brand new headlight - £10
- Cabby wing mirrors, small crack on one - £5
- Single Pirelli P slot - £15
Last edit: by louiesmall
1992 Sportline Cabriolet in Red
Thanx Shane
Cheers Gaz
