Bits and pieces
(In Topic #188320)
Clearing the hoard-can take to AGM!
I have a small collection of parts sat in my garage that are of no use to me.
I have added prices for the rules but please send me a message if you are after any parts.
What I have-
*Caddy mk1 tow bar- £SOLD
*Golf GX servo- £10
*GX steering wheel fair cond- £Sold
*Tin Top fuel tanks straps good cond- £15
*Head rests X3 (2x Mk1, 1x Recaro)- £mk1 h/rests prov sold. Just the Recaro one left £5
*Seat knobs and trims (mixed mk1/Corrado/recaro)- £3 ea
*90mm driveshafts (pair), will need joints- £10
*mk1 5dr sill repair panel-new- £10
*Solid Brembo discs-not much use- £13
*Interior door handles X2- £3ea
*OMP lower front strut brace- £prov sold
*Std door pins (plastic x4)- £3
*GTi centre console (has two hole drilled for switches)- £10
*eibach EZ shim rear camber shims- £5
*Mk2 GTD downpipe- £15
*GTi rear ARB- £10
*2x new big block oil filters- (Petrol)-£3ea
*Heater box- £10
*Heater matrix (used but doesn't leak)- £5
*Ht leads (GTi?)- £4
*Ht leads and cap- £4
*Handbrake- £5
*Chrome sill trims- £sold
*Rear stub axles, drum backing plates, new pads/cylinders and fittings- £12
*Door handles (mixed lot of mk1/2 golf)£ask
*Rear carpet plate/trims x3 - £5ea
*Brake pads 2 sets low use/as new £5 set
*Brake servo bracket/mount- £10
*Steering cowling trim- upper half only-£3
*Relays (mixed lot)- £ask
*Seat runner carpet trim/cover x2- £5
*Headlight x2 - £8
*Headlight rings/mounts x2- £8
*5dr rear 1/4 glass and seals x2- £5 ea
*Heated rear screen-Tintop- £8
*Weighted gear linkage (mk3)- £10
*Std gear linkage- £3
*Gearbox rear mount bracket- £5
*Front engine mount cup (big block)- £5
*Cig. Lighters x1- £3
*Chrome door latches (off of Audi 80-set of 4)- £20
*Clutch cable (1.6 used)- £3
*Ashtray- £3
*Oil cap- £2
*Coolant cap- £2
*OEM wishbone bush x2- £2
*Rear arb bush x1- £2
*Brake resevior bottles x3 -£3 ea
*Heater control knobs (OEM)- £3
*Audi 80 window winders- £3 ea
*Fuse box (GX)- £5
*Dash heater duct pipe x1- £2
*Header tank- £3
*Fuel tank filler hose (new)- £Sold
*Poly bush engine mount insert x1- £5
*Mk2 GTD heat shield- £5
*Wheel nuts (mixed lot)- £ask
*Brake linkage bar- £8
*Bonnet prop bar- £4
*Debadged grill (all clips intact)- £SOLD
*Caddy exhaust (not that old-had it fitted with my GTD. Was cut on removal but sections can be used). £30 sold
All items can be collected or I can take to the AGM on the Sunday or VW Action on the Saturday
Will post smaller items.
Any questions please feel free to ask
Location is Welwyn Garden City.
What I have-
*Golf GX servo- £10
*GTi rear ARB- £10
*Heater box- £10
*Handbrake- £5
*Headlight x2 - £8
*Ashtray- £3
*Oil cap- £2
*Coolant cap- £2
*Fuse box (GX)- £5
*Header tank- £3
Last edit: by cavs
1987 Caddy 1.6Turbo Diesel-GTD
Instagram: Cavscp
Instagram: Cavscp
Are the ex shims new? If so ill take em At agm on Sunday
I don't suppose there is the spring on that servo bracket. I only need the spring !
I would like the pair of seat runner/carpet trim covers (if part no begins 171) could meet you in same place one evening.
Cavs, can I have the headrests please
And would the Audi chrome door latches fit a clipper cabriolet, thanks
bugs-gti- the EZ shims are new. I will check whether it is a pair or just one
Jonny 16v- what spring would that be? Any pics?
Abfmk1- I will check the part number today.
Skipper1- which headrests would you like?- the door latches were from an Audi 80 so I am guessing they will need a little fettlibg with the mech/levers on the back
If anyone is after parts in the London area I will be going to the meet tonight
Instagram: Cavscp
Instagram: Cavscp
I'll have the 2 mk1 black headrests please,I'll get them off u tonight😄
Okay mate-I'll bring them with. Anything else??
Instagram: Cavscp
Instagram: Cavscp
Just the headrests, cheers
Okay mate
Instagram: Cavscp
Instagram: Cavscp
Cheers pellet me know
Hey bud, on the bracket for the servo, right behind where it attaches there's a round bar inside. The spring should be on that if you have it
Yeah that's the one mate
Any luck on the shims mate
Hey
Instagram: Cavscp
Instagram: Cavscp
Hey, I think there is only 1 shim per pack. I only have 1 pack if it's of use to you?
Instagram: Cavscp
Instagram: Cavscp
How much would you like for the spring?? Not going to agm as I'm at work :-(
Would need a pair mate as cant have one cambered wheel lol
