G60 conversion
(In Topic #212504)
Done any one know what engine mounts to use when putting in a g60 into a mk1 ?????
G60 conversion
Thanks mateRaul said
G60 conversion
Where do I get the rubber bushes for them mate???
I forgot to ask, what gearbox are you using.
That kit I linked is to use the g60 02a gearbox. If you're using your 020 box you don't need all those mounts.
G60 conversion
Only just brought it and not sure in what gearbox to be onest will thay work for both
G60 conversion
I had a look at some paper work it says it's got a vw corrado g60 gearbox???
Is the engine in something else already then?
G60 conversion
It's already in the mk1 golf but not been put in right as it's touching the left side of engine in the engine bay hitting the pulley tensioner not good lol
Right, gotcha. Just buy a proper mount for that side then.
http://www.classic-vw.co.uk/mk1-golf-epytec-308-16v-g60-19tdi-engine-conversion-mount-5498-p.asp
Probably been bodged, it's a known issue with fitting a g60 engine. But try and get some photos up of the other mounts too, just so we can clarify what's going on.
Is it the tensioner bracket hitting the chassis leg? You can get a thinner bracket on the good old bay of E for about £25
