Stereos with more of a factory look!!
(In Topic #219883)
If you're worried about power than a small in line amp could be the answer. Alternatively a Becker type unit may be what you're looking for.
They make radios for high end cars generally. Such as Merc, Ferrari etc
for example https://www.ebay.co.uk/itm/Becker-BE7925-Indianapolis-CD-Navigation-Head-Unit/292892274796?hash=item4431bd706c:g:pwcAAOSws2RcJOmP:rk:2:pf:0
Otherwise look for older Alpine units as Alpine was around in the 90's so you could have a period 'upgrade'
https://www.ebay.co.uk/itm/Alpine-Ipod-Car-stereo-CDE-9882Ri/163459382701?hash=item260ef03dad:g:yygAAOSwikBcKTP6:rk:12:pf:0
Especially if you can find the ones that light up green. I did in the end but I can't remember the model number. It's in my build thread somewhere!
Ian
https://www.amazon.co.uk/Speaker-Converter-High-Line-Level/dp/B004UA753G
Regarding amps, you need to be careful when comparing outputs - a lot of manufacturers will state something like 50W, but this is actually peak. Proper amp figures should be RMS. e.g. 20W RMS (explained better here: https://www.kicker.com/app/misc/support/tech/tech_papers/docs/PeakVsRMS.pdf)
So, whilst your unit may say 50W, it's probably not RMS. Worth bearing in mind when comparing amps. You can get some pretty small units these days (have a look on Amazon) and you may be able to fit one under the seat.
The pinoeer above is a bit too retro as its a 1992 cab so a factory black face is more in keeping
https://www.ebay.co.uk/itm/Blaupunkt-Alicante-CD30-CD-Radio/173685205455?hash=item287071e9cf:g:RrwAAOSwGMJa0kdB
(I'm not helping am I!)
https://www.caraudiocentre.co.uk/product_m-alpine-ktp-445a_p-26445.htm
Last edit: by ajc1984
https://www.caraudiocentre.co.uk/product_m-pioneer-gm-d1004_p-32858.htm?refSrc=26445&nosto=productpage-nosto-2
Pretty compact, you could probably fit it on the tunnel behind the lower centre console….
You won't damage headunit or speakers provided you wire it up correctly. I spent many an evening fitting headunits, speakers (even used to make up MDF parcel-shelves for folk that wanted decent 6x9's in the back) in my late teens. All work was done for beer and Marlboro's. I think I did a few for my mates older sisters friends - they were FOC of course
paceman said
That item is designed to plug and play with Alpine units, one review mentions a universal one, but it's not on the site. This however would do the job (and it will take speaker level inputs).
You won't damage headunit or speakers provided you wire it up correctly. I spent many an evening fitting headunits, speakers (even used to make up MDF parcel-shelves for folk that wanted decent 6x9's in the back) in my late teens. All work was done for beer and Marlboro's. I think I did a few for my mates older sisters friends - they were FOC of course![]()
Good idea on mounting behind tunnel would have to have a measure up also price is good. It needs a constant 12v supply than an ignition 12v, where would you get the constant 12v from cig lighter or would that circuit not be up to the 'load' I have found the apline universal one whats the pros and cons between the 2 in your view as the alpine one is very compact so would defo fit anywhere in car?
ajc1984 said
I know there are a few sound pros on here so what's the thought on this little unit, looks like it would do what i needed it (boost an older standard units power output) is there a risk in using something like this, i.e. popping speakers or damaging headunit ect? They seam to get great reviews everywhere. Im no pro so all im trying to do is fit something like a gamma headunit thats a bit more 'factory looking' but need to boost the power output as they are only 20watts and my new speakers are higher rated so dont want to have bought good speakers and then fit them to a low powered headunit!!
That's exactly the one I was going to recommend. My mate runs https://www.carelecderby.co.uk/products/4581743495 and they use loads of them for exactly what you're trying to do.
As the wiring loom input is designed for Alpines you may need to do a bit of unpinning and re-pinning of the terminal block to make it work with another head unit but totally do-able.
Give them a ring and have a chat. Tell them Ian (Jezs mate ) told you to call.
Otherwise there's something like this https://www.ebay.co.uk/itm/Bluetooth-Vintage-Car-Radio-MP3-Player-Stereo-USB-Classic-Style-Car-Stereo-Audio/113203657303?_trkparms=aid%3D555017%26algo%3DPL.CASSINI%26ao%3D1%26asc%3D55148%26meid%3D64a2c1d5f4b14e958bb63bb1d98fb0d7%26pid%3D100505%26rk%3D1%26rkt%3D1%26%26itm%3D113203657303&_trksid=p2045573.c100505.m3226 but I think it's a bit 'old' personally.
Ian
https://www.ebay.co.uk/itm/Continental-tr7411u-or-Car-Radio-12V-with-RDS-System-MP3-USB-AUX-Berlin/162792749767?_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D20140107083358%26meid%3Defc033915e1a4471b604fc834cbc714a%26pid%3D100011%26rk%3D2%26rkt%3D12%26mehot%3Dlo%26sd%3D163253887989%26itm%3D162792749767&_trksid=p2047675.c100011.m1850
got one in my r129 and sounds good, it fits right in as well, the ado one suits the golf obviously, shame the backlighting isn't green though
