Mk1 power steering rack
(In Topic #216024)
Can someone clarify this is a power steering rack for a mk1 golf please
There should be a VAG number on it and we can cross check that number…. it appears also to be LHD
Thanks for your help
nas said
Wasn't to sure as I didn't know they did a power steering rack for the mk1 lhd there is a tag on it with numbers I'll grab it tonight
It was fitted to some Cabby's from very late 90 until end of production in April 93. The Sportline for example! 😉
Sent from my Smartphone 📱
So it appears that this is the manual version…
Brilliant thanks so it should be a straight fit in my 82 mk1 lhd gti the spline from the steering knuckle will fit ?
I do know that on my LHD Autos there isn't a bracket.
I do know that on my LHD manuals there was a Bracket for the Relay shaft…. it was more square like in the breakdown picture than the rounded protrusion….
I may take a closer look at my Rack as I have to change the Steering Pump today.
I do know that if you change out a Steering shaft and wheel on a Air-Bagged 90 Cabriolet you have to get the scirocco or early type of u=joint coupler to mate the new steering shaft to the Rack Be it Manual or Power in the 90ish over here on this side of the pond.
