Mk1 Golf GTI Reverse light Switch
(In Topic #216527)
![nickvw in the usergroup ‘Local’ nickvw in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Now Working Lights
As my MOT is due next week I decided to tackle it again, and not sure how I managed it but I have adapted the 3 pin type to fit the 2 pin type. Firstly I fiddled with a multi meter until I got a circuit between 2 pairs of pins, and found a pair that worked.
Hopefully with some pictures you will see from the pictures what I mean. The old one at the bottom showing the 2 sets of connections.
![IMG-0478.JPG IMG-0478.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1519552641/uploads/attachments/5a92887fb9489.jpg)
The new one at the top I found a circuit between 31-3 and 15-R. So \I then carefully pulled back the rubber boot and exposed the plug and accordingly moved the connections to the corresponding pins, Like this.
![IMG-0479.JPG IMG-0479.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1519552938/uploads/attachments/5a9289a93abc8.jpg)
This is how the connections were when I pulled the rubber boot back. The bottom 2 are the reverse wires. I used a set of small tweesers to push a small tab down and pull the wires out. The Pic below shows how I connected them in the new switch. Result is Working Reverse Lights !
![IMG-0480.JPG IMG-0480.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1519553069/uploads/attachments/5a928a299bbe1.jpg)
MK1 Golf GTI 1900
MK2 Jetta GTI 16V
MK2 Jetta GTI 16V
![Roach in the usergroup ‘Local hero’ Roach in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Well done on fixin it tho!!
MK1 Golf GTI 1900
MK2 Jetta GTI 16V
MK2 Jetta GTI 16V
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Reverse lights will have to be checked then.
Good job on getting the switch working
