Is my car Tax & MOT exempt
(In Topic #232456)
My car is an 81 reg. How do I check if its tax and mot exempt?
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
from your build thread i can can see its not on original supplied engine, so depending on MOT or log book, then the rules say it should be classed as the newest major part.
https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/670431/vehicles-of-historical-interest-substantial-change-guidance.pdf
As for MOT unless your competent at mechanical work and confident that you have rectified faults when occur then its up to you to decide whether to take it for test. Ive said before and will say again, get it checked over by independant garage, and if god forbid you have accident then you can prove the car is maintained and road worthy. There's enough junk on the road that's 10yrs old nevermind 40.
On the drive
Myvalver 89 GTi Grey mk2 16v
There's a bunch of other non-engine rules too.
In my mind, 16V engine was not okay but 2.0 8V would be okay; and obviously anything the Mk1 came with originally eg 1.8 8V would be fine too. But then its all rendered moot because you can self-declare!
Same for mot exemption if you declare it un-modified.
As Kenneth says, Best bet is to carry on with an mot test each year - at least then you have proof of 'roadworthiness' if anything bad happened.
