Alternator Brushes
(In Topic #222393)
Briano1234 said
That is the old Motorola type of Alternator, it is most likely a voltage regulator issue.
Thanks Briano Any ideas where to get a regulator from
* This is a Special Order item. We will order it for you immediately, but it may take up to six weeks to arrive, unless it is a TMI part, which may take up to 12 weeks to arrive.
Easier to convert it over actually or go to a Local rebuilder and see if they have it on hand.
1st thign take the reg off, and check it. there are 2 electrical contact points which need to be clean. if the brushes look obviously damaged or too short, then replace.
take it into local GSF or euro, see if they have one on the shelf that fits.
thanks guys
so anyway. brush pack looks ok, are the grooves in the alternator deep? if not then that side should be ok./ take your brush pack into local motorfactors and see if they have any which match
