A Turkey Baster isn't just for the Kitchen.
(In Topic #212431)
I have found it useful for some of the following chores.
Removing Fluid from the Expansion Jug prior to a sensor removal.
Removing fluid from the Sensor outlet on Digifants.
Removing Brake Fluid from the res prior to a MC swap.
Adding Acid or water to the Battery.
Removing power steering fluid from the res prior to removing the pump.
Blowing air in a hard to reach area.
Sucking up spilt fuel that has pooled.
I have worn out 3 or 4 of them over the years and usually the Kitchen gets a new one when I have the need and the one in my shop is leaking air.
What have others used it for car wise?
Last edit: by Briano1234
Just don't make the mistake of placing it back in the kitchen when you're done… the wife didn't like that too much.
Fausto said
Great tip! Much more cost effective than syringe-based options sold at automotive stores.
Just don't make the mistake of placing it back in the kitchen when you're done… the wife didn't like that too much.![]()
Well I do rinse it out, between uses but mmmm the taste of Turkey or Beef with au jus of 90wt…..yummmmm yumm
