Youtube video Golf mk1 engine swap 1.5JB -> 1.8EX
(In Topic #221051)
Hello everyone,
My name is Stijn (dont try to pronounce that) and im new to this forum.
Recently ive been making youtube videos about the engine swap of my 1982 volksxagen golf mk1.
Ill leave the link to the videos here if anyone is interested.
Ep1: https://youtu.be/rqkYd3a7Uxw
Ep2: https://youtu.be/_U8YpSuBaNc
Im not the best videographer nor am i the best mechanic so please be gentle in the comments
Thank you!
Last edit: by Memphis
Welcome Memphis,
Watched the videos and you have done a good job but there is a couple of things I would do different like
I found it alot easier to remove the drive shaft flange bolts with the tool above the drive shaft flange so the angle of the shaft and rubber boot don't interfere with the tool you are using.
Exhaust manifold C clamp clips, your way is very dangerous as the clip could ping off in any direction, either buy the right tool for £10 ish or use an up-turned exhaust clamp to spread the clip open. (guides on the web)
https://www.ebay.co.uk/itm/Exhaust-Spring-Clamp-Removal-Tool-VW-Audi-SEAT-Skoda-300mm/254062633112?epid=1540660530&hash=item3b27502098:g:2ccAAOSw8zNcOD3n&frcectupt=true
Exhaust manifold nuts, I would use new copper locking nuts each time I remove the manifold as you don't want them coming undo over time as they are a pain to get to once the engine is in.
https://www.ebay.co.uk/itm/VW-GOLF-MK1-MK2-MK3-T25-CAMPER-CORRADO-EXHAUST-MANIFOLD-LOCK-NUTS-x-8-A713/191413095873?hash=item2c911c0dc1:g:Bv8AAOSwnDxUbael
Your front wheel bearing may also be shot now as it's not a good idea to roll the car about with out the drive shafts fitted in the hub, the bearings are under load from the big nut at the end. I also loosen the hub nut with the car on the ground on its wheels so you don't pull the car off it's jack by mistake.
It's just a couple of things I would do different but please keep us updated on how things go and good luck…
You're right about the wheel bearings! Front left was shot but has already been replaced
Currently the swap is done but i still have to finish editing all the episodes.
Thank for the tips!
Thank for the tips!
Let us know when it's done.
I did enjoy the first 2 clips and you have a good looking car.
Love the videos mate
