Updated loom
(In Topic #211441)
to go whith,thank you
You will lose about 14 feet of wire between the Battery to the headlight switch and back to the headlight bulbs take the Hi-current off the headlight Circuit.
The Bulbs go from 11-11.5V to Battery 12.5-14V (depends on battery and alternator).
There are 2 types of looms, or ways to do it.
One has 2 relays, and the other 3.
The 2 relay is for low and high beam.
The 3 relay is for low, High/low.
The 3 relay kit allows the Low beam to activate whenever the Highs are on increasing the light available.
I have the diagrams for you in (HOW I Relayed my headlights.)
Relaying your Head Lights | Volkswagen Owners Club Forum
http://www.ebay.com/itm/2-Headlight-H4-Headlamp-Light-Bulb-Ceramic-Socket-Plugs-Relay-Wiring-Harness-Kit-/262483542712?hash=item3d1d3d02b8:g:FGgAAOSwQNRXLlAl&vxp=mtr
Look for Fused and Ceramic bulb sockets…. I am not endorsing them, only showing you what is out there.
ebay: headlight Relay kit.
dont want to loose all the lights if one pops. ideally 4 fuses and relays so one per side for both dip and main, but tbh 1 fuse/relay for main is ok really as you dont use main all that often and if you lost it can switch back to dipped
Looms up? & ive looked at osram nightbreaker H4 bulbs
But it's saying not compatible with my car?,I have an 89
Clipper cab,any ideas if they will fit my car? Thanks
many of the kits you see on ebay are bought in from china for sod all and posted up with a hefty markup (just shows you how cheap they are from china when you look at the costs here!) so shop around carefully you want quality stuff!
any normal H4 bulb will fit fine, just be aware if you go too mental they get hot enough to melt the glue holding on the glass, especially if the units are getting on a bit. Once you have uprated the loom and bought nice new genuine hella lamps you dont need to go too crazy though
