Time for a service - Part suggestions wanted pls?
(In Topic #200571)
Evening all,
Have got a couple of days off during "kiddy week" (half term) so will take the opportunity to service the car (91 plate Clipper), can I ask suggestions on parts please e.g. oil filter, plugs, oil etc, does it really matter what brand I go for, currently looking at carparts4less as they seem good value?
All suggestions welcome, thanks in advance.
www.vwspares.co.uk are good for service items. carparts4less are EuroCarParts - they sometimes struggle to tell the difference between a mk1 cabby and a mk2, which means you get the wrong parts!
2001 Zafira 1.8
2001 Zafira 1.8
I buy Quantum Synta oil which is perfect, £20ish for 5l, original VW oil filter from eBay for less than a tenner and put a sports air filter on so it does not need changed.
What mileage has the engine done?
It can make a big difference!
Thanks for all the replies, a bit more info for my car: -
1/ 122,000 miles
2/ Been standing for a wee while (hence the service)
3/ Won't be used over the winter (call me a wuss)
PS is 10w40 Semi-Synthetic oil best to use?
Thanks again.
1/ 122,000 miles
Thanks again.
Quantum Synta 10w40 👍
Life Member
Drain and change oil and replace oil filter - £25 job
Replace fuel filter - £5 job
Bleed brake fluid and change - fairly cheap job
Also maybe get the wheels off and check the brakes and pads - pads are fairly cheap too
I also try and shampoo the interior twice a year - autoglym shampoo £10
Spark plugs are fairly cheap too if they are looking a bit worse for wear and fairly easy to do
Personally i would use fully synthetic oil, renew fuel filter, air filter, Oil filter (a must with a service) Sump plug & washer - possibly sump gasket too. Also check service/receipt records for head gasket & rocker cover gasket change… Brake fluid change? gearbox oil, check brake hoses not corroded…. just a few things. Wynns also do a fuel cleaner as well for your fuel lines..
perhaps think about using high performance fuel only in ya car. like Shell Nitro…
