Suspension advice
(In Topic #237454)
It's going to have the family in for meets and weekend use only, so needs to have a relatively comfortable ride but only just losing the tyre under the arch.
Also will anything need doing with the arches? It's my first mk1 so any advice appreciated 👍🏻
Arches depend on wheel offset and tyre choice.
Anything other than bc, gaz, h&r or kw are pretty useless unless you want a damaged spine.
Bc aren't cheap, but very much worth their money.
https://www.ebay.co.uk/itm/233057944785?hash=item36435604d1:g:xowAAOSwVjBhqAsQ&amdata=enc%3AAQAHAAAAwLAmgbI3KlVIWT4UKFjm5VlV5YM%2F2w31me8e3u7IyRK9DF0kK5el7Kh379oZwEAZD%2BWDimUN%2FOjOhQ9JfTpL%2Bt5sVI0tUMyr5lR1aiC2lTB4TKkvMWhy8En%2FSaN7q%2F7xCsvOZzomfEETFr6QWBnjSQLW3oYTdxy7HiTzWpjZKwkIq4J5jpLKFLVr4TVdi6bDcVYqHuX530Qq%2FF8L8fUtaMBZgCI6CORsshKCFB5R%2BCj9Ix5p8pZZK60SvkVvyua0nA%3D%3D%7Ctkp%3ABk9SR7L9paLzYA
Got the set up on both my cars and very happy with the ride, it can get a little bumpy on rough roads but with any type of lowering suspension it needs to be a bit stiffer than stock to stop you hitting the floor.
I'm very pleased with my recently fitted GAZ Coilover kit which I got a decent discount on via Larkspeed's Ebay store. These are made on order and it takes about 6 - 7 weeks for delivery. You can also order them directly from GAZ.
I also fitted new suspension rubbers and mounts that I sourced from Heritage parts.
Being coil overs, you can set the ride heigh of course, but I've gone for -10mm from factory.
Current Mk1's
1992 VW Citigolf CTi 1.8i (UK)
Previous MK1's
2006 VW Velociti 1.6i (UK)
1992 VW Mk1 Golf Clipper 1.8 carb (UK)
2000 VW Mk1 Citigolf Life 1.6i (SA)
1991 VW Mk1 Citigolf Sport 1.8 carb (SA)
1983 VW Golf Mk1 GTS 1.6 carb (SA)
Previous MK1's
Roach said
Bc racing on my 76. Very comfortable when set to fully soft.
I've seen you mention these numerous times on various threads so im sold on how good they must be. Could you please just confirm if you bought the normal or extra low version to get your ride height?
I ended up going for SSP coilovers from Herirtage Parts. Suspension is a little harder than id like but manageable. Worth it for the look 😜
Either will achieve that height I believe. Mine are the extra low ones tho, wishbone on the floor low… pretty silly.
Cheers. Looks like your wheels are nicely tucked under with a big offset to keep them away from the arches.
I recently bought the set of 15x6.5 BBS RM that Jake posted for sale on here. They're et33 which I thought was right for the mk1 but they do stick out more than I would like. They have 195 50 15 tyres on which I'm looking to change, maybe for 175 50 or 185 45. Not many tyre brand options in those sizes though.
Much prefer the tucked in look. Also helps with keeping the arches safe from the tyres!
See I'm a tuck man, 33 in my world is on the edge of about right… I like 38 and higher. A tyre change to a 165/45 on a 6.5 would help it massively tho. Also with the bc, they come with camber adjustable top plates, so you can pull the front wheels in slightly to clear the arch.
One final question on the coilovers - you mentioned they ride better than stock when fully soft. How feasible is it to run them soft without arch meeting tyre? In reality do you have to run them firm when you drop a reasonable amount?
ESEN said
Cheers for the info. Might need to reconsider my wheel choice!
Well yeah if you deck it you'll have to firm them up a bit, but they're still very comfy.
Your spring rate choice will play a large part in that.
Would go for the softer spring rate. 5/3 I think it is
ESEN said
Yeah, not going to deck it, but a reasonable drop.
I wouldn't if yours is a gti. Mines on them but is only a little 1.1 small block. I'd probs go 6/5 or somewhere around there. Your choice tho of course.
Last edit: by Roach
ESEN said
Everywhere I've looked says 5/3 is standard and stiffer is if you have a cabriolet or an engine swap for a heavier lump, but I'll make sure I check again. Cheers
Ah fair do's. Maybe the weight difference isn't as different as I'd first thought.
They come with camber adjustable top mounts but what happens to the camber adjustment that already exists on the hub/strut?
Is that no longer used? Does the eccentric bolt need to be replaced with a standard bolt? Should that be set to zero camber and then use the top mount to adjust camber?
Whilst I'm asking questions.. 2 more on this…
Do you need to use normal top mounts with them as well as what's supplied?
Can you use coltech top mount raisers with them and would that be worth it?
Cheers all!
