Some help with my problem will be much appreciated :)
(In Topic #185054)
Mk1 golf C 1.1 1982
link to my project post: http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmy-first-car-project_2
Make sure your are getting fuel through to the carb. If not you either have blocked lines or a weak diaphragm in the fuel pump, use compressed air (a foot pump will do!) to blow the lines through. If fuel comes through to the inlet make sure there are no blocks in the carb, clean out the carb and check the jets are clear. Use compressed air and carb cleaner, don't stick anything in the jets.
If you know fuelling is good then check for air leaks, splits in vacuum hoses, base mount gasket from carb to inlet manifold etc. You can check base mount by running the car and spraying around the mount with carb cleaner. if the revs pick up you have an air leak. When the car's running the air leak will increase and cause the mixture to lean out.
Once you've covered off the fueling then if the fault persists you need to go over the ignition system. If your on points and condenser then check the points are clean and the gap is correct. The faults described could be a failing condenser (cheapest) or a failing coil (more expensive).
I had a similar problem a while back with our Polo - the trouble I found was that the fault was intermittent and so when I tested everything it was working fine - I solved it by taking my testing gear in the car and waiting till it failed (Hall sender on Polos electronic ignition was the culprit in my case).
Check the Haynes manual, there will be instructions for testing the condenser and coil in there.
Good luck with it, do it in order and it will be easier to trace
