Seat: inner seat release cable
(In Topic #233437)
Seat
1988 GTi Cabrio, the inner seat release cable has just snapped, is an an easy fix?
Or any upholstery companies in Preston Lancs area?
Last edit: by urbanracer
you can temporarly fix with chocolate clock connectors until new 1 arrives,
On the drive
Myvalver 89 GTi Grey mk2 16v
Its quite a common issue and its a while since I've done one.
There's a guide link below, but from memory I fixed whilst seat in the car and poss used the old cable to pull a new wire through. As above you can repair the existing cable or I've used welding or electrical wire before that was around for free
2-Door\Cabriolet Seat Back Cable Replacement | Volkswagen Owners Club Forum
Another fix is use a bit of wire to lift the catch out the way if it's only 1 side broken, mine been like this for a few years and not problem MOT time.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=technical%2Fbodywork-fittings-and_2%2Ffront-seats-wont-tilt
Hi
My cable snapped a couple of months ago.
I followed the quick link guide as noted by Early-1800 which was very helpful. I found that someone had already used 2 x electrical connectors (as Kenneth has mentioned) and a bit of wire to join the snapped length together. one of these connectors had come loose, so i just retightened the connectors and left well alone.
I have owned the car for over 10 years before the wire gave way so obviously its a quick fix that can last for a good while.
Thanks for replies,I have owned the car since 1996.
I have got some ideas.
One problem is while at garage they pulled the cable off so I do not know where the top part is to join.
Some of the diagrams are good but if anyone one has it I would like to know the way the cable goes from the top to bottom middle.
I've got my seat in bits so I'll try and remember to take a picture for you later on…
Thanks that will be great
About the best ones I have.
Many Thanks thats great as they say a picture paints a thousand words.
Better than the ones I took!
