Respirator paint spraying mask advice
(In Topic #212963)
Hi,
Can anyone recommend or offer advice on respirators suitable for use with aerosol spray tins and also Holts colour mix paints used with a air compressor and spray gun. I assume both paints are acrylic? The reason I ask is I have been spraying some wheels and although the JSP & 3M re-usable half mask I've tried are fitted with organic and particulate filters and make an air tight seal I can still smell paint or thinners through them. Can anyone offer advice?
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
I used to spray polyurathene paint using a 3m usable half mask. I asked the health and safety guys about as I could still smell. They told me the filters take away the harmful parts and and the smell is nothing to worry about. I used to be spraying up to 8hours at a time, as long as you don't start feeling dizzy or headache you should be fine
That's interesting, I will look into this further. Thank you for your help
Why not just go to your local automotive paint shop and buy one there?
It's all about the fit of the mask.
You need to be clean shaven with no beard for 100% face sealing. The mask also needs to fit your face. There are different types and manufacturers and they are all different so you may need to try some other brands.
The filters also need to be changed regularly and need to be suitable for the use to which you are putting them.
A paint shop or H&S equipment supplier should be able to help. Try to avoid DIY shops as they don't know what they are talking about generally.
Ian
Ian
That is exactly what I did
Cheers for your help Ian. I have already tried your suggestions apart from speaking to H&S officer so will look into this. In your opinion with everything correct should I be able to smell anything through the mask?borednow said
It's all about the fit of the mask.You need to be clean shaven with no beard for 100% face sealing. The mask also needs to fit your face. There are different types and manufacturers and they are all different so you may need to try some other brands.The filters also need to be changed regularly and need to be suitable for the use to which you are putting them.A paint shop or H&S equipment supplier should be able to help. Try to avoid DIY shops as they don't know what they are talking about generally.Ian
