Oil
(In Topic #207047)
2001 Zafira 1.8
2001 Zafira 1.8
http://www.ebay.co.uk/itm/VW-Golf-MK2-MK3-Cabrio-1-6-1-8-GTI-Engine-Oil-Pump-Repair-Kit-/181772748034?hash=item2a52800502:g:V9IAAOSwrklVeseV
Halfords Classic Oil 20W50 5L | Halfords UK
Last edit: by robtech
Oil
That is a bigger issue. Sorry no answers but should help you make a decision.
10W40 semi synthetic, and a good oil filter, VW, Mann is what you really want.
http://www.vwspares.co.uk/
I change my Mk1 Scirocco every year and I only do about 3,000 miles a year, Golf is every 10,000 miles as it my daily and I cover that mileage in a year.
Spark plugs and air filter are not so much a problem, fit a K&N panel filter and you never have to change your air filter again, just clean it every 50,000 miles! £40 for a K & N panel filter, the type that lives in your air box NOT A BOLT ON replacement type as you lose the hot air feed and the cold air feed from the front of the car and lose power.
http://www.ebay.co.uk/itm/33-2002-K-N-SPORTS-AIR-FILTER-GOLF-MK1-1-6-1-8i-1976-1983-/291489492957?fits=Model%3AGolf&hash=item43de20afdd:g:I4wAAOSwaNBUkYIZ
Last edit: by mark1gls
BAZ-GTI said
Thanks mark, I have a k&n which came with the car but I put a Mann in as the k&n was quite dirty, is there anyway to get it clean it or is there special chemicals that have to be used, Thanks
There is a cleaning kit you can buy, cleaning fluid which you soak the filter in, wash the cleaning fluid off with water then let it dry, once dry re oil the filter.
The kit will clean the filter many times so should last for years!
http://www.eurocarparts.com/ecp/p/-/-/-/-/?508771111&0&cc5_9999
