New clutch needed !!
(In Topic #235081)
Best place to get quality clutch & cable from for sportline
I'm in need of new clutch and cable for my sportline would you go for Sachs?? I want to to be good quality one nice light smooth it will definitely ease up the drive .
Where could I purchase full kit from?? Also roughly how much labour for to get it fitted . Any help be great .
The sachs kit is good, I have used two of them, you just need to have the proper size, as in the diameter of your original. Be warned that some of the aftermarkets have the 6btdc hash on them but not the 0 (TDC) stamped to the right.
as in
190mm, 200mm, 210mm as your pressure plate requires the proper disk.
Cables are best ordered from VWheritage or werk34.de
Make sure that your clutch feed through isn't weakened, or loose. You will need the correct length, so you mat want to measure yours to get the proper fitment.
Year and engine/tranny are nice to know.
Tip, when ever I did a clutch, I replaced the release bearing, the clutch finger, as well as the bushing at the clutch end that the push rod goes through.
front bush
Release bearing
Finger
as in
front bush
Release bearing
Finger
Thank you for feedback appreciate that 😉 , it's a lot to think about . Nothing worse ordering parts and don't fit correctly!! 😫😫
so I'm going to double check sizes before order
Karl
Karl
