Mk2 throttle body
(In Topic #233293)
Notices the idle adjuster screw is missing from the throttle body.
They a near impossible to find.
Question is - do I need it. Given I am running bosh K jet.
There might be one on the mk1 body I can swap into a it but have not had chance to look at it just yet.
Thx
Mk2 throttle body
Worth a punt for less than £20.
https://www.maxrpm.de/Idle-screw-for-Golf-MK1-Golf-MK2-GTI-16V-GTI-Scirocco-EX-DX-EG-KR16V
But I believe this is what is missing from my throttle body.
mine looks more like:
https://bahnbrenner.com/vw_audi/products/1450/VW_Idle_screw_for_2H_PG_(G60)_9A_PL_KR_engines_(OEM_051_133_432)
And I wrap the threads of the thing with Teflon Tape.
Mk2 throttle body
You've likely already found this out, but if not when you register to their site you've to give a postal address, that presumably automatically alerts them to delivery costs to outside of Germany / potential duty differences, both of which are calculated at the checkout stage.
I believe German VAT is 19% at the moment, but regardless of that they'll charge you our current 20% by default and the paperwork'll reflect that when it enters into the UK - so you shouldn't have anything extra to pay on that score as you already have.
If it's just the throttle body screw you're buying, its value is potentially below the threshhold for paying import duty… check that though
I think I'm right in saying the items value includes it's postage cost and the threshold is low.
When I used them we were still in an interim grace period where automotive stuff wasn't yet being charged import duty so long as the item was made in the EU… again I think that's possibly no longer the case and duty is now applied.
On a lowish value item it's not so much the duty that'll cost you, it's whatever the admin. fee you can get hit for that stings.
I'm N.Ireland, things may be different here to the rest of the UK… what I was finding was some couriers were taking it on themselves to do the paperwork prior to entry into the UK / paying the duty on your behalf then charging over the odds for the service… don't pay them, they don't deliver.
If that doesn't happen and Customs themselves tug it / charge you, the same'll apply, but it was always a much lesser fixed admin. fee.
MaxRPM did the paperwork flawlessly, but as I said we were only contending with the VAT back then, things could very easily have changed dramatically since!
J
https://www.maxrpm.de/Adjustable-vernier-pulley-camshaft-pulley-for-all-G60-engines-18L-PG
I know it says G60, but the cam pulley is the same part number as the MK1.
I do like the look of this one https://www.maxrpm.de/Adjustable-billet-vernier-pulley-camshaft-pulley-for-all-G60-engines-18L-PG
but no one will ever see it!
It was because I wasn't 100% sure it'd be for my 1.8 EV and that made me waver.
Things have changed a little on their site… previously it adjusted the VAT rate to the UK 20% automatically, it now appears to charge no VAT at all leaving it up to you / the courier to sort that bit out for yourself on entry to the UK.
Suppose it cuts their export / import admin. down to the bare minimum for them and if there's any hic-ups they don't have to get involved?
Had a quick scan of the Govt.UK site again and it too is subtly different, emphasis now seems to have shifted from the seller collecting the VAT to the courier instead.
As you say the import duty threshold is £135 and it does include the postage… wonder does it also include the courier admin fee as well?
If so that might have the potential to push you over into paying it?
Different goods have different duty rates… if you have to pay it, I've no idea what classification your vernier wheel'll be under to find out its rate.
Keep us posted how you get on, both cost wise and the spec. of the wheel to see if it'll suit my engine… cheers.
Yep, they don't charge any VAT as you say, saves on their paperwork (unlike the big outfits like Autodoc).
I'll let you know what I get stung for!
