Master cylinder
(In Topic #233349)
I have fitted a g60 servo to the mk1.
Just went to look at the master cylinder fitting and pipework arrangement. In short it won’t work with the one I have as it’s an abs master cylinder.
Looking at this one I think it will work but would love some advice before I spend even more money on the money pit.
https://www.gsfcarparts.com/652vg0250?auto_apply_coupon=SHOP60&gclid=EAIaIQobChMIhf7-teLa8QIVArDtCh2RKQHWEAQYASABEgIrJfD_BwE
Also if this one is suitable then can anyone recommend ‘T’ pieces to fit the brake light switches back in as I assume on the 4 ports I with have
1 for back to the compensator valve
2 for the front
1 I will use for the 2 brake light switches. - hence t piece.
Can’t use a mk2 GTI cylinder by the was as the fixing bolts are on an angle.
2 for the front
No,, 2 run back to the compensator valve, one for each side
Master cylinder
Had another look and see the diagonal plumbing.
Will fit a T piece on one of the front ports and one on the rear port of the master cylinder to add the brake pressure switches back in. Found some on Amazon for under a tenner each.
Feel like I have too many part done jobs at the moment with this thing. Need some time to finish the master cylinder fitting and inlet manifold change. Then I can be back out of the engine bay to the rear axle and fuel fuel system again.
