Exhaust fumes inside car when window is down
(In Topic #212785)
I've recently noticed exhaust fumes coming into the car when driving with the window open. I've replaced the tailgate seal for a new genuine item which has helped but I'm still getting fumes in the car. I also checked to make sure the exhaust isn't leaking and all holes are covered. Anyone else have this problem or can offer any advice.
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
All 3 of my 90 Cabriolets had cracked manifolds.
Then on Toilet Bowel exhausts the Gasket between the manifold and the down pipe can get holed and leak there….
I have also had exhaust pipes get holed on the top where you can't see them, as well as the rear silencer (muffler) look brand spanking new on the bottom but caved in at the top.
There is also a Rubber seal on the Rain tray if missing can cause the fumes to enter through the heater blower.
Also is it a standard exhaust. It had the problem before - not on a golf - where the exhaust pipe stopped just an inch short or so of where it should be and it basically got caught in the back draft behind the car at slow to moderate speed and made it way in. Cheep check for this is to buy one of those cheep chrome tail pipes and extend the exhaust but put some duck tape around to give a good seal, do a test drive and see. If gone the you know the issue just then need to find a fix that looks up to standard. Note don't leave the tape on permanent it will melt and make smells come in the car.
here should also be a seal inside the car which is around the UJ.
Looks like this but picture is not great and showing the side view.
http://www.ebay.co.uk/itm/Steering-column-bulkhead-seal-Golf-MK1-Jetta-Scirocco-Caddy-171419547A-Genuine-/172750539117?hash=item2838bc096d:g:eVkAAOSwq~tZUiaC
