D t a
(In Topic #220793)
Has anyone got any knowledge on using dta Ecu
2.0 9a engine
My cars not starting and I’m out of ideas
2.0 9a engine
which one have you got, they do a few versions. what rpm trigger are you using, is there any life at all out of it, can you connect to the ecu etc
D t a
I’m going to plug it in on Monday
I’m unsure what version it is
il get some photos of unit and see if I can work it out
Do the ecu ever fail
The car seams to be doing everything apart from starting
I have fuel and good spark
Just changed plugs , leads , fuel and still the same
ecu can fail, but not common. main thing is if its been setup properly on the engine rpm trigger side as theres lots of ways to do it and settings need to match what you got
D t a
Cars been running for 4 years on same set up
I ran out of fuel and then it won’t start again
ah ok so that side should be all fine, assuming its running off the distributor maybe check the hall sensor and wiring to it. once connected to the ecu you should see engine rpm while cranking on the starter if all is well I expect
on the fuel side does the ecu trigger the fuel pump ok? maybe check you got good flow to the rail. do the plugs smell of fuel?
D t a
I’m running direct coil from Renault magan
I thought similar and changed crank sensor but still no joy
So I’m looking for replacement coil ASAP
Il let you know how I get on
Thanks so much for advice mate I’m going to give it another go this weekend
D t a
Also I’ve checked the in pipe to fuel rail and return pipe and both giving out plenty of fuel
so have you got a custom crank sensor setup on there? does your ecu show you cranking rpm
D t a
Yes custom crank is from a ford transit lol
I changed it to be safe but no result on it starting
This is why I just wanted someone to plug it in and see if it reads any obvious faults
