Clock repair
Hi all
Anyone on here repair mk1 clocks or know of anywhere who doesn't charge the earth.
My miles at the bottom don't work the red 9 gets to that position and stops.
Also the blue plastic membrane stuff with all the electric bits on is very dirty on the wires what would be best to clean it with?
Need to do a repair on the plastic bracket aswell it's snapped off [emoji2361]
Sent from my Pixel 8 using Tapatalk
38 views (68 Kb)
48 views (50 Kb)
48 views (26 Kb)
There is a red gear in the Speedo that is probably loose on the shaft or has broken teeth.
I would dust it off as trying to clean the mylar may cause you more grief than you want.
Easy to fix if you have the skills take your time.
https://www.cabby-info.com/files/gauges/RepairingTheOdometer.pdf
Terrymoyce87 said
Hi all
38 views (68 Kb)
48 views (50 Kb)
48 views (26 Kb)
crazyquiff provides a repair service. He fixed my cabby clocks and they still work. 😎
