Clock help
Hi
I don't seem to have the black section on the back of my clocks is that a issue? I also noticed the blue material don't go over the top. My click just goes on a white section what does this plug/part of the clock do?
Sent from my Pixel 8 using Tapatalk
62 views (39 Kb)
62 views (47 Kb)
Clock help
Also
What's the other plug I see on clocks it's green with like a black vacuum pipe off it. That for MFA?
Terrymoyce87 said
Also
Yes, for mpg in lcd.
Clock help
Any help on this?
Are my clocks meant to light up when I turn the key?
Terrymoyce87 said
Any help on this?
No
Clock help
Thank for that
Doesn't say much about this part. I don't have the black plastic bit or the blue wrap going over it.
Changed all my bulbs and they don't work still
71 views (41 Kb)
If you used LED bulb replacements, they are Polarity aware, and you may have them in backwards.
The Power for the lamps come in on the Gray/blue wire,
You may want to Verify that you have Voltage on that pin to pin 2 (brown) ground.
