Brake Lights
(In Topic #240547)
Then at the end of the day whilst putting the car away, it appeared that the brake lights weren't working.
Is the faint indicator LED and non working brake lights related.
Bad ground are another issue at the tails.
More likely to be the pedal switch or connected wiring and unrelated.
If you get brake lights that permanently stay on, in a dual filament bulb one filament can blow, metal joining the two circuits inside bulb.
You start with the fuses and bulbs and hope you have nothing else to do…
