A Pillar Fairings-Butyl Fixing
Hi
Anyone know where I can get some of the sticky butyl blocks to fix the fairings back on the A pillars . Mark at Classic VW had some at the annual gathering but only come as part of a kit with the plastic deflectors.
ta for any info
on etka there is a note 'also use D 438 515 A1 which is 'double sided adhesive tape' not cheap at 26.94+VAT though!
found a pic for reference if you want to buy some more generic double sided tape off the bay of e:
looks liek VW use it for just about anything that wants sticking to the shell, badges, sill trims, etc
If you have a double glazing company near you it's the same stuff they use for bonding glass into frames
lhasa green 83 gti tintop MOT passed Aug '14 after nearly 12 years!
swb transporter 6.1 Highline 150
Thanks for your suggestions. I hadn't thought about using double sided glazing tape which will do the job. I've ordered a roll of 6mm tape which seems to be the thickest available.
