Last Bits from my '83 GTI and Garage!
(In Topic #147660)
So i have the following all from my '83 1.8(DX) Tin Top GTI unless stated:
- Dashboard (Black) Good Condition
- Dashboard lower storage bins
- Centre console
- Heater slides and cables
- Golf C/GL black plastic sill trims
- Black rear trim cards
- 2x hockey stick door seals
- Boot Trim (black cards)
- Speedo Cable
- Radiator
- Radiator Fan Cowling
- GTI Steering Wheel
- GTI Distributor
- Horns (2 off incl bracket)
- GTI Oil Cooler, bracket & hoses
- Radiator Fan Switch
- Front Suspension Camber Bolts
- Blaupunkt Woodstock DAB Radio, loom and DAB aerial adaptor
- Inlet Manifold
- Inlet manifold piping
- Golf C 3dr Drivers Door (no rust)
- Warm Up Regulator
- (-30mm) lowering springs
- Alternator
- Haynes Manual (Blue) think its the recent one.
- Assortment of random bolts thrown into a box during dismantling (job lot won't split)
- Assortment of random grommets, washers, cable transits etc (nowhere near a full cars worth and no idea what some of them are - job lot won't split)
UPDATE
- Front hubs
- GTI Servo
- Assorted glass let me know what you're after.
- Battery tray, good nick, removed from car - no major damage.
- Window Winder Mechanism (front 3dr) not sure what side. If interested i can figure it out.
All parts can be posted within mainland UK at cost, but please be sensible when asking. A door couriered ain't going to be cheap!! I'm based in north east england so all parts can be collected by arrangement.
Email me at tchoyland@googlemail.com if you're interested in any bits.
Tim.
Dom123 said
Do you have the black trim from the inside of th boot lid?
Which bit are you after? Is it the long rectangular bit that goes on the hatch over the wiper motor/mech ?
peeriehutchie said
an overnight ferry crossing plus a 300 mile drive yes , hah , couriers are aware of this too and sock a £20 surcharge on small packages even , which might only contain a £5 item , i tend to avoid couriers like the plague they are
Let me know what you're after and a postcode on a mail to tchoyland@googlemail.com, and I'll see what I can do on postage.
smudger1980 said
When you say assorted glass I don't suppose you've got some front opening quarters windows??
I wish!! Think they might have been sold a few times over if I had of!!! Got some normal quarter lights if that's any help?
sandi12 said
Do you have rear brake valve compensator?
Sorry already sold. Let me know if there is anything else you need though.
That's right yes, would need postage too
paulio007 said
pm'd m8
No pm received.
Yep got it PM sent.
paulio007 said
pm'd m8
PM received and returned!!
