Whats does the REAR BRAKE COMPENSATOR DO?
(In Topic #90456)
There is a plate and spring on the valve attached to the rear beam axle [on the passenger side] , the more weight in the rear of the car the longer the valve stays open . smaller engined MK1's 1100, 1300 and some 1500 models didn't have one .
Cabriolet and later than about 1983 models used a pair of valves mounted on the master cylinder [these are still available from VW but are very expensive]
that do the same job as the earlier rear beam mounted item .
If you suspect that the rear beam compensator is faulty then replacement is the only option , luckily Car Parts & Spares -- Buy Online with Fast UK Delivery | GSF Car Parts still sell these items .
