MK1 1.1 Brakes
(In Topic #74987)
MK1 1.1 Brakes
Have just started driving my MK1 1100 Golf after about 8mths of driving a MK2 16v.
Just a quick question as i can't remember are the brakes on a MK1 always almost non-existant?? I have changed the discs/pads and bleed the whole system and no change.
Cheers!
RJ
My Build Thread
It Takes a lot of effort to stop it. I had 2 previous 1.1 & had the same problem.
Check the Mastercylinder if it is not leaking or something.
By changing that it will make a lot of diffrence.
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
To get the best out of them, check these first:
New fluid? - makes a huge difference over stuff that looks like Guinness!
Front calipers siezed? - either the pistons in the body, or (more likely) the caliper body/hub carrier interface is rusty, causing jamming.
Rear drums' wedge-adjusters not taking up the slack correctly, causing lots of pedal travel - clean-up required.
Pivots on cross linkage get rusty, causing loss of force between pedal and master cylinder - pop the clips off the stainless-steel pivots and remove, clean, & grease.
If all this is good, and you're still not happy, you can fit the bigger calipers and 239mm discs from the GTI, but you will get much longer pedal-travel if you do nothing else, due to needing more fluid to fill the bigger cylinders on the GTI calipers.
I would highly recommend replacing the discs, pads and calipers for Gti items. Easy job - straight swap.
My Build Thread
I have a gti master cyl & servo in my garage if you want them - I have recently replaced them with rado 16v jobs. I assume they will fit :dontknow: & you can have them if you wish.
Mark
Bert
'83 Mars Red 1.1 C
Mk1 VW Golf 'c' restoration job....
